This command displays the details of specified or all groups. The information contains group name, grop status, LMEP id, the physical port of the LMEP, RMEP ids, registered clients, domain and association names.
| group_name | Group name, maximum of 31 characters. |
N/A.
Use this command to display the details of specified or all groups. The information contains group name, grop status, LMEP id, the physical port of the LMEP, RMEP ids, registered clients, domain and association names.
The following output shows the typical output of this command:
# sh cfm groups Group : eapsCfmGrp1 Status : UP Local MEP : 11 port : 41 Remote MEPs : 10 Client(s) : eaps Domain : MD1 Association : MD1v2 Group : eapsCfmGrp2 Status : UP Local MEP : 12 port : 31 Remote MEPs : 13 Client(s) : eaps Domain : MD1 Association : MD1v2
# show configuration cfm
# Module dot1ag configuration.
create cfm domain string "dom" md-level 5
configure cfm domain "dom" add association meg "VSNLMEG1" vlan "v1"
configure cfm domain "dom" association "VSNLMEG1" ports 1 add end-point down 100
configure cfm domain "dom" association "VSNLMEG1" ports 15 add end-point down 200
configure cfm domain "dom" association "VSNLMEG1" ports 1 end-point down add group" erps-g1"
configure cfm domain "dom" association "VSNLMEG1" ports 15 end-point down add group "erps-g2"
configure cfm group "erps-g1" add rmep 300
configure cfm group "erps-g2" add rmep 400
# show configuration "erps"
# Module erps configuration.
create erps erps_major_1
configure erps erps_major_1 add control vlan v1
configure erps erps_major_1 ring-port east 1
configure erps erps_major_1 ring-port west 15
configure erps erps_major_1 timer wait-to-restore 5000
configure erps erps_major_1 cfm port east add group erps-g1
configure erpserps_major_1 cfm port west add group erps-g2*
# show cfm detail
Domain/       Port      MP   Remote End-Point   Remote End-Point MEP     Life          Flags
 Association                    MAC Address        IP Address    ID      time   Age
dom
 VSNLMEG1
               1        DE     -------------    0.0.0.0           300    3500    0       SMA
               15       DE     -------------    0.0.0.0           400    3500    0       SMA
Maintenance Point: (UE) Up End-Point, (DE) Down End-Point
Flags: (S) Static Entry, (D) Dynamic Entry
       CCM Destination MAC: (U) Unicast, (M) Multicast
       Status: (A) Active, (I) Inactive
NOTE: The Domain and Association names are truncated to 13 characters, Lifetime
      and Age are in milliseconds.
Total Number of Dynamic Up RMEP      : 0
Total Number of Dynamic Down RMEP    : 0
Total Number of Active Static RMEP   : 2
Total Number of Inactive Static RMEP : 0
# show cfm groups
Group : erps-g1  Status : UP
        Local MEP       : 100     port   : 1
        Remote MEPs     : 300
        Client(s)       : erps
        Domain          : dom
        Association     : VSNLMEG1
Group : erps-g2  Status : UP
        Local MEP       : 200     port   : 15
        Remote MEPs     : 400
        Client(s)       : erps
        Domain          : dom
# disable ports 1
# show cfm detail
dom
 VSNLMEG1      1        DE     -------------    0.0.0.0           300    3500    0       SMI
       CCM Destination MAC: (U) Unicast, (M)Multicast
Total Number of Active Static RMEP   : 1
Total Number of Inactive Static RMEP : 1
# show cfm groups
Group : erps-g1 Status : DOWN
       Remote MEPs     : 300
       Client(s)       : erps
       Domain          : dom
       Remote MEPs     : 400
       Client(s)       : erps
       Domain          : dom
# enable ports 1
# show cfm detail
dom
VSNLMEG1       1        DE     -------------     0.0.0.0          300    3500    0       SMA
# show cfm groups
        Remote MEPs     : 300
        Client(s)       : erps
        Domain          : dom
        Remote MEPs     : 400
        Client(s)       : erps
        Domain          : dom
This command was first available in ExtremeXOS 15.2.
